.#.h3d file
The .#.h3d files are compressed binary files, containing model, analysis, and optimization result data. They can be used to post-process results in HyperView or when using the HyperView Player.
File Creation
The .#.h3d files are created when the OUTPUT, H3D, <frequency>, BYITER output option is present and an optimization is performed.
File Contents
Result | Description |
Acceleration | Acceleration results
from frequency response, transient response, and
dynamics analyses. Output is controlled by the I/O Option ACCELERATION. |
Composite ply strain | Ply strain results for
composite materials from static analyses. Output is controlled by the I/O Option STRAIN and by the SOUTi field on the PCOMP definition. |
Composite ply stress | Ply stress results for
composite materials from static and analyses. Output is controlled by the I/O Option STRESS and by the SOUTi field on the PCOMP definition. |
Composite failure indices | Failure indices for
composite materials from static analyses. Output is controlled by the I/O Option STRESS, by the SOUTi, SB and FT fields on the PCOMP definition and by the related fields on the relevant material definition (see MAT1, MAT2, MAT8). |
Density | Density results from
topology optimizations. Output is controlled by the I/O Option DENSITY. |
Displacement | Displacement results
from static, frequency response, transient response, and
multibody dynamics analyses. Output is controlled by the I/O Option DISPLACEMENT. |
Eigenvector | Eigenvector results
from normal modes and linear buckling analyses. Output is controlled by the I/O Option DISPLACEMENT. |
Element force | Element force results
from static, frequency response, acoustic, and transient
response analyses. Output is controlled by the I/O Option FORCE / ELFORCEFORCE. |
Element strain energy | Element strain energy
results from static and normal modes analyses. Output is controlled by the I/O Option ESE. |
Grid point stress | Grid point stress
results for 3D elements from static analyses. Output is controlled by the I/O Option GPSTRESS / GSTRESS. |
Shape | Shape results from
topography or shape optimizations. Output is controlled by the I/O Option SHAPE. |
Single-point force of constraint | Single-point force of
constraint results from static analyses. Output is controlled by the I/O Option SPCFORCE. |
Strain | Strain results from static, frequency response, transient response, and multibody dynamics analyses. Output is controlled by the I/O Option STRAIN. |
Stress | Stress results from
dynamics analyses. Output is controlled by the I/O Option STRESS / ELSTRESS. |
Thickness | Thickness results from
size and topology optimizations. Output is controlled by the I/O Option THICKNESS. |
Velocity | Velocity results from
analyses. Output is controlled by the I/O Option VELOCITY. |
- The # in the file name is the iteration number.
- Grid point stresses are output for the entire model and for each individual component. This allows grid point stresses to be accurately obtained at the interface of two components referencing different material definitions.
