Install PostgreSQL
In this section you will learn how to install PostgreSQL.
It is recommended to perform the installation using the default values and options. Also, when prompted for a Windows admin password, you can use your Windows password.
- Open a command prompt in admin mode.
Launch the installer (postgresql-10.1-2-windows-x64.exe or later version) from
the command prompt.
Note: You should launch the installer from the command prompt only. This will auto-resolve the path to Windows native utilities needed for PostgreSQL to install and work correctly.
Launch the pgAdmin 4 tool (included with the installation), and add one user
with full rights:
Expand the Servers node until you have exposed
the Login/Group Roles node, as in the following image.
Right-click on Login/Group Roles and select Create > Login/Group Role... from the context menu.
The Login Role dialog box is displayed.
- On the General tab in the Name field, type hweuser.
- Click on the Definition tab, and in the Password field, type hwe_123.
Click on the Privileges tab and set all fields
to Yes.
Click the Save button.
Note: The connection limit should be set at 30.
Create a customized pg_hba.conf file:
- Open a text editor, such as Notepad, on your system.
Copy and paste the following code into the text editor.
# PostgreSQL Client Authentication Configuration File # =================================================== # # Refer to the "Client Authentication" section in the PostgreSQL # documentation for a complete description of this file. A short # synopsis follows. # # This file controls: which hosts are allowed to connect, how clients # are authenticated, which PostgreSQL user names they can use, which # databases they can access. Records take one of these forms: # # local DATABASE USER METHOD [OPTIONS] # host DATABASE USER ADDRESS METHOD [OPTIONS] # hostssl DATABASE USER ADDRESS METHOD [OPTIONS] # hostnossl DATABASE USER ADDRESS METHOD [OPTIONS] # # (The uppercase items must be replaced by actual values.) # # The first field is the connection type: "local" is a Unix-domain # socket, "host" is either a plain or SSL-encrypted TCP/IP socket, # "hostssl" is an SSL-encrypted TCP/IP socket, and "hostnossl" is a # plain TCP/IP socket. # # DATABASE can be "all", "sameuser", "samerole", "replication", a # database name, or a comma-separated list thereof. The "all" # keyword does not match "replication". Access to replication # must be enabled in a separate record (see example below). # # USER can be "all", a user name, a group name prefixed with "+", or a # comma-separated list thereof. In both the DATABASE and USER fields # you can also write a file name prefixed with "@" to include names # from a separate file. # # ADDRESS specifies the set of hosts the record matches. It can be a # host name, or it is made up of an IP address and a CIDR mask that is # an integer (between 0 and 32 (IPv4) or 128 (IPv6) inclusive) that # specifies the number of significant bits in the mask. A host name # that starts with a dot (.) matches a suffix of the actual host name. # Alternatively, you can write an IP address and netmask in separate # columns to specify the set of hosts. Instead of a CIDR-address, you # can write "samehost" to match any of the server's own IP addresses, # or "samenet" to match any address in any subnet that the server is # directly connected to. # # METHOD can be "trust", "reject", "md5", "password", "scram-sha-256", # "gss", "sspi", "ident", "peer", "pam", "ldap", "radius" or "cert". # Note that "password" sends passwords in clear text; "md5" or # "scram-sha-256" are preferred since they send encrypted passwords. # # OPTIONS are a set of options for the authentication in the format # NAME=VALUE. The available options depend on the different # authentication methods -- refer to the "Client Authentication" # section in the documentation for a list of which options are # available for which authentication methods. # # Database and user names containing spaces, commas, quotes and other # special characters must be quoted. Quoting one of the keywords # "all", "sameuser", "samerole" or "replication" makes the name lose # its special character, and just match a database or username with # that name. # # This file is read on server startup and when the server receives a # SIGHUP signal. If you edit the file on a running system, you have to # SIGHUP the server for the changes to take effect, run "pg_ctl reload", # or execute "SELECT pg_reload_conf()". # # Put your actual configuration here # ---------------------------------- # # If you want to allow non-local connections, you need to add more # "host" records. In that case you will also need to make PostgreSQL # listen on a non-local interface via the listen_addresses # configuration parameter, or via the -i or -h command line switches. # TYPE DATABASE USER ADDRESS METHOD # IPv4 local connections: host all all 127.0.0.1/32 md5 host all all 0.0.0.0/0 trust # IPv6 local connections: host all all ::1/128 md5 # Allow replication connections from localhost, by a user with the # replication privilege. host replication all 127.0.0.1/32 md5 host replication all ::1/128 md5
- Save the file to a location on your system. You will use this file in the next step.
- Using Windows Explorer, locate the pg_hba.conf file that you created in the previous step and move it to the <PostGres_INSTALLATION_DIR>/data folder to replace the file already there.
- Open the Windows Task Manager, Services tab, and locate the postgresql-x64 service.
Restart the postgresql-x64 service by right-clicking on the service name and
selecting Restart from the context menu.
Figure 3.Note: This allows all users to connect without authentication.
- Reconnect to the server by clicking on the username, hweuser, and selecting Yes when prompted to reconnect.
- Optional:
If you need to locate the port number for the server connection, click on the
name of the server and then click the Properties
tab.
Figure 4.The Port number is listed under Connection, as displayed in the image above. Knowing the Port number allows you to share the connection with other users.
