Optimization Output Files
Output files generated from an Optimization.
<opt_variable_name>.hyperopt
File Creation
This file is created during an Optimization study.
File Location
<study_directory>/approaches/<opt_variable_name>/<opt_variable_name>.hyperopt
File Contents
Result Format Description
Protocol file ASCII Contains all information about the optimization progress and convergence. You can open this file in the text editor of your choice.
  1. The default opt_variable_name is opt_i, where i is the number of the respective optimization study.
<opt_variable_name>.opt
File Creation
File Location
<study_directory>/approaches/<opt_variable_name>/<opt_variable_name>.opt
File Contents
Definition of the optimization problem ASCII Contains HyperOpt input data.
<opt_variable_name>.hstds
File Creation
This file is created when Apply is selected during the Specifications step.
File Location
<study_directory>/approaches/<opt_variable_name>/<opt_variable_name>.hstds
File Contents
Run Matrix Data hstds, binary Hstds files stores the retained data sources; direct access data using the .hstds file is not suggested.
<opt_variable_name>.hstdf
File Creation
File Location
<study_directory>/approaches/<opt_variable_name>/<opt_variable_name>.hstdf
File Contents
Run Matrix Data hstdf, binary Hstdf files store the run data; however, direct access to the data using the hstdf files are not suggested.
<opt_variable_name>.status
File Creation
File Location
<study_directory>/approaches/<opt_variable_name>/<opt_variable_name>.status
File Contents
Status Report ASCII Contains the final status report on the optimization convergence.
