Verification Output Files
Output files generated from the a Verification.
<verify_variable_name>.hstds
File Creation
This file is created when Apply is selected during the Specifications step.
File Location
<study_directory>/approaches/<verify_variable_name>.hstds
File Contents
Result Format Description
Run Matrix Data hstds, binary Hstds files stores the retained data sources; direct access data using the .hstds file is not suggested.
<verify_variable_name>.hstdf
File Creation
File Location
<study_directory>/approaches/<verify_variable_name>.hstdf
File Contents
Run Matrix Data hstdf, binary Hstdf files store the run data; however, direct access to the data using the hstdf files are not suggested.
