A resource file establishes the basis of the connection to HyperStudy. Information
about the input variables and/or output responses are passed through the file.
If you are defining an Interanl Math
model, dragged-and-dropped a model file into the application, or invoked HyperStudy from another HyperWorks Desktop application, you will not be
required to manually load a resource file.
In the Define Models step, Resource column of the model you are defining, click
In the HyperStudy - Load model resource dialog, navigate
to your working directory and open the resource file.
Note: If you load a file for a Parameterized File
model that does not contain parameters, a dialog will appear asking if you
would like to parameterize the file. If you select
Yes, the file will open in the
Editor as a *.tpl file. When
you close the Editor, HyperStudy
automatically loads the*.tpl in the Resource column,
and inserts the file name in the Solver input file column.
