The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperStudy. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
The status bar, located at the bottom of HyperStudy, displays supplemental information about your study.
The right-side of the status bar displays information about
the step you are currently on.
Figure 1. Example: Status. The status reads, /Beverage Can/Setup (Nominal Run, 1
Steps)/Evaluate to indicate that you are currently in the
Evaluate step of the Setup in the Beverage Can study and will be performing a
nominal run.
The left-side of the status bar displays the number of errors
and warnings in the current study.
Tip: View a detailed list of the
warnings and errors by clicking the message in the status bar.
