hwIPage GetWindowIDList
Gets a list of the window IDs.
hwIPage_handle GetWindowIDList
HyperWorks Tcl Modify
This command returns a list of the window IDs within the page. They can be used later in commands such as AddWindowSyncGroup to specify which windows you want to use in the command.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowIDList;
Error
Success (the window ID list) or an error message is returned.
Keywords
HyperWorks
Tcl
Modify
