plt3DISurface GetPolygonMode
Returns the surface’s polygon mode.
plt3DISurface_handle GetPolygonMode
HyperWorks Tcl Query
Returns polygon mode; transparent, opaque, or wireframe.
None.
View new features for HyperWorks Desktop 2020.1.
Gets a handle to a plt3DICursor interface for the surface.
Gets the color of the surface.
Gets the handle of a particular data source from the surface.
Gets whether a surface is displayed in the legend.
Gets whether surface is highlighted.
Gets the color of mesh lines superimposed on the surface.
Returns the surface’s mesh mode.
Gets a named meta-data value previously associated with the surface.
Gets whether a curve’s X, Y, and Z vectors are parameterized by U and V vectors.
Gets whether surface is visible.
Sets the color of the surface.
Sets whether a surface is displayed in the legend.
Sets whether the surface is highlighted.
Sets the color of mesh lines superimposed on the surface.
Sets the surface’s mesh mode.
Associates a named meta-data value with the surface.
Sets whether a surface’s X, Y, and Z vectors are parameterized by U and V vectors.
Sets the surface’s polygon mode.
Sets whether the surface is visible.
ON THIS PAGE
None.
ON THIS PAGE
