pltICurve CalculateStatistics
Calculates a statistic.
pltICurve_handle CalculateStatistics template_idx
HyperWorks Tcl Modify
This command calculates a statistic template based on the input statistics template index and returns the calculated statistics.
- template_idx
- A number corresponding to the index (position) of the statistic template within the statistic template list that you want to use.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetCurveHandle c1 1
c1 CalculateStatistics 1;
Keywords
HyperWorks
Tcl
Statistics
Modify
Create
