pltICurve HighlightRangeByValue
Highlights between two values.
pltICurve_handle HighlightRangeByValue from_value, to_value, marker
HyperWorks Tcl Modify
This command highlights between two values by putting lines at the two values and highlighting the part of the curve in between the two lines. This is different from HighlightRangeByIndex in that it measures between two values rather than two indices.
from_value
A number representing the value along the X or Y axis (depending on which type you choose for the marker) that you want to use for the minimum value.
to_value
A number representing the value along the X or Y axis (depending on which type you choose for maker) that you want to be the maximum value.
marker
Type of marker that you want to use to highlight.
modify_horizontal
Which takes the horizontal range, making vertical lines
modify_vertical
Which takes the vertical range, making horizontal lines
statistics
Taking a statistical range
none
Which clears the highlighting completely
Examples
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetCurveHandle c1 1
c1 HighlightRangeByValue 2 5 modify_horizontal;
Keywords
HyperWorks
Tcl
Cursor
Modify
