pltICurve Trim
Applies a trim edit to the curve.
pltICurve_handle Trim from_val, to_val, orientation, interpolate
HyperWorks Tcl Modify
This method only applies the edit. Call the Recalculate method on the parent plot object to update the data.
from_val
The minimum value of the range to be trimmed.
to_val
The maximum value of the range to be trimmed.
orientation
The orientation of the edit.
horizontal
vertical
interpolate
True
Create new data points at from_val and to_val (using linear interpolation) if they are not already there.
False
Do not create new data points at from_val and to_val
Returns success or an error code.
