pltINote SetRasterPosition
Sets the position of the note.
pltINote_handle SetRasterPosition x, y
HyperWorks Tcl Modify
This command sets the position of the note (in pixels). This command differs from the SetPosition command in that it uses pixels rather than relative positioning.
x
The horizontal position of the note (in pixels).
y
The vertical position of the note (in pixels).
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetNoteHandle n1 1;
n1 SetRasterPosition 250 35;
Keywords
HyperWorks
Tcl
Note
Modify
