poI3DViewCtrl GetImagePlaneHeight
Gets the height of the image plane associated with a stored view.
poI3DViewCtrl_handle GetImagePlaneHeight name
HyperView Tcl Query
Returns the image plane height in term of number of pixels. This image plane is the one associated with the view. Along with width, it is used to recalculate view properties given the cropping situation.
name
If specified, the offset of the view with that name will be returned. Otherwise, the current view’s offset will be returned.
To get the image plane height of a view named "View 1":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle GetImagePlaneHeight “View 1”
hwi CloseStack
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
