poIComponent SetMeshMode
Sets the component’s mesh mode.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle SetMeshMode mode
HyperView Tcl Modify
This command sets the component’s mesh mode.
mode
The mesh mode: edges, features, meshlines, or none.
Error
Returns 0 if successful, otherwise an error code.
