poIFBDCtrl GetCurrentCSValueList
Gets the values for the currently selected cross section.
poIFBDCtrl_handle GetCurrentCSValueList context
HyperView Tcl Query
This command is used to query the values for current selected cross section. This function is currently used for table mode generation and is not advised to use for the general public. This command currently runs the FBD and RES forces/moments for a selected cross section on a current subcase.
context
Cross section FBD and RES values.
Error
None.
