poIFBDCtrl SetIgnoreNodeSet
Sets whether or not the node selection should be ignored.
poIFBDCtrl_handle SetIgnoreNodeSet context
HyperView Tcl Modify
This command sets whether or not the node selection should be ignored.
- context
- A boolean value (True or False).
- True
- Will ignore the node selection and just use the nodes from the element selection.
Returns 0 if successful, otherwise an error code.
