poIResultCtrl SetCurrentSubcase
Sets the current subcase for result manipulation operations (for example: animation, contour, and vector plot).
poIResultCtrl_handle SetCurrentSubcase id
HyperView Tcl Modify
This command sets the current subcase for result manipulation operations (for example: animation, contour, and vector plot).
id
Set to a positive integer.
Returns 0 if successful, otherwise an error code.
