poIStressLinearizationCtrl SetComponentsToPlot
Specifies the tensor components to be included in the HyperGraph plot.
poIStressLinearizationCtrl_handle SetComponentsToPlot compsToPlot
HyperView Tcl Modify
This command specifies the tensor components to be included in the HyperGraph plot. The default value is XX YY ZZ XY YZ ZX.
compsToPlot
The tensor components to be included in the plot.
To specify the tensor components to be included in the HyperGraph plot:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl SetComponentsToPlot compsToPlot
hwi CloseStack
None.
