poIVectorCtrl SetEnabled
Sets the dimension state, either enabled or disabled.
poIVectorCtrl_handle SetEnabled pool state
HyperView Tcl Modify
This command sets the dimension state, either enabled or disabled.
- pool
- The pool from which to set the enable state.
- state
- True if enabled, otherwise false.
Returns 0 if successful, otherwise an error code.
