Create and View Section Cuts
Use the Section Cuts tool to cut planar or spherical sections through a model.
Create Section Cuts
View Section Cuts
Delete Section Cuts
From the View Controls toolbar, click
In the Section Cuts dialog, do one of the following:
- Right-click on a section cut and select Delete from the context menu.
- Select a section cut then click
