Create Derived Load Cases
The File Loader allows you to import results from native load cases, in the HyperMesh data base, as well as via Load Combination file, to create derived load cases in the form of linear super-position and/or envelope. Use the Derived Load cases tool for the creation of these derived load cases.
From the menu bar, click .
Figure 1. Linear Superposition
Figure 2. Envelope
Envelope can be either min or max, and it requires, where available, the definition of the relevant metric, for quantities such as vector and tensor.
Each newly created derived load case (DLC) is appended to the list and can be reviewed using the context menu. DLCs are then available in all of the other result tools.
Figure 3.
