Results Processing Tools in HyperMesh
The results post-processing workflow is now embedded in HyperMesh, and you can seamlessly process solver native results in HyperMesh. The File Loader is used to generate the new results entity.
From the menu bar, click .
Topology, connectivity and systems are taken from the HyperMesh model.
Once the result entity is generated, it can be seen in the Model Browser. Right-click and select Show Files to display the native files used as the source by the results entity.
To input the native result files that you want to process, use Load Combination File, which is optional. You can also generate new derived load cases in the form of Linear Super-Position or Envelope, with a metric definition in the case of envelope.
Once the result entity is created in HyperMesh, you can save it in the database. The entity will be stored as a pointer to that result file, and virtual results with derived load case definition, if any. Memory duplication of any of the results will not affect the HyperMesh database.
