Organize Design Points
Besides the Auto DDP option, you can organize your model using the other options available in the context menu.
Paste
Paste design points that were previously cut or copied from another design point set. This does not result in new design points created, but a reference inside target design point set.
Remove
Removes a reference to a design point from its parent design point set, but does not delete it from the database. However, if design point does not exist in any other design point set, then design point will be deleted too.
Cut
Cuts design points.
Copy
Copies design points.
