Create Cylinders
Use the Solids: Cylinder tool to create cylinders with solid or bounding surfaces.
Solids: Cylinder Tool
An overview of the Solids: Cylinder tool.
Figure 3.
- Access
- Go to .
Keyboard Shortcuts and Mouse Controls
To do this | Press |
Draw base diameter instead than radius | Ctrl + Left Mouse Click |
Edit cylinder | Double-Click |
Snap to alternate orientation | Tab |
