Midlines Tool
An overview of the Midlines tool for working with solids.
Use the Midlines tool to quickly create center lines for tubes and solids. You can also create connectors on these center lines to create seam welds.
- Access
- Go to Solids in the selector. and select
Options
- Destination component
- Specifies which component the midlines will be created in. Values can be:
- Mask input geomety
- Hide input solid geometry in the modeling window upon exiting the context.
- Create seam connectors
- Create seam connectors on the center line using either of the following: Density (specifies the number of connectors to be created on the center line) or Spacing (specifies the distance between connectors).
