Combine Solids
Use the Boolean: Combine tool to connect two or more solids together, retaining all of the material in both.
Boolean: Combine Tool
An overview of the Boolean: Combine tool.
- Access
- Go to .
Options
- Find tolerance
- Tolerance to use to find intersecting solids. By default, it is set as geometric tolerance.
- Keep common interface
- Retain any common surface, interface, after combining solids.
- Use Parasolid
- Parasolid geometrical kernel is used for executing the operation.
