Offset Components
Fine tune offsets by components.
You can fine tune offsets in both the displacement system and the elemental system. Typically this is done when you need to update a large selection of elements.
  1. Select the element(s) you want to offset in the model.
  2. Click the Offset in system button to display the X, Y, and Z values.
  3. Type in the appropriate X, Y, and Z offset values and press Enter.
    The selected elements will offset accordingly.
  4. If you need to undo the offset, press the Reset offset button on the far-right of the microdialog.
