Orient Beam/Bar as Plate Stiffener
Align the beam/bar axis along the positive normal of an adjacent shell.
Normals of adjacent shells are averaged since they do not have an angle greater than the threshold value (break angle) defined in the options. For sharp angles, the shell with the lowest ID is used as a reference. In the case of T-junctions, you can select a reference shell by hiding undesired shells and by setting the "normal from shells" option to Displayed.
