Component Test Rigs
MotionAuto provides Auto Entities, for example bushings and dampers, to model components commonly employed in vehicle suspensions. To better understand the behavior of these entities, MotionAuto provides component test rigs you can explore the entities' force-deflection and force-velocity characteristics.
Available Component Test Rigs
- AutoAirspring
- AutoSpring
- AutoBumpstop
- AutoDamper
- AutoReboundstop
The following section illustrates the steps to assemble an AutoSpring test rig model. The same steps can be used to create test rig models for the auto entities listed above.
