Constraint Toolbar
The Constraint toolbar provides you quick access to the Joints, Advanced Joints, Couplers, Motions, Gears, and General Constraints panels.
![](../../images/post_processing/mv_model_constraint_toolbar.png)
Joints | Allows you to edit properties, connectivity, orientation rules, and initial conditions for joints. |
Motions | Allows you to create motions and to edit the initial conditions, displacements, velocities, and acceleration of joints. |
Couplers | Allows you to edit joint couplers. |
Gears | Allows you to create a gear entity to relate the motion of two joints. |
Advanced Joints | Allows you to create a set of joints where points, curves and surfaces stay in contact throughout the simulation. |
General Constraints | Allows you to create a generic expression based constraint. |
