Subsystems Toolbar
The Subsystems toolbar provides you quick access to the NLFE Stabar Subsystem, NLFE Helical Spring Subsystem, and Belt-Pulley Subsystem dialogs.
- NLFE Stabar
- NLFE Helical Spring
- Belt-Pulley
Stabar (Stabilizer bar) and Helical Spring can be used in automotive applications for the suspension. Helical springs can also be used in various other applications.
![](../../images/post_processing/nlfe_subsystems_toolbar_mv.png)
Figure 1. Subsystems Toolbar
From the View menu, select
and then click on a toolbar name to turn the display on/off for the selected toolbar.![]() |
NLFE Stabar Subsystem |
NLFE Helical Spring Subsystem |
Belt-Pulley Subsystem |
