Deformable Strut
In the deformable strut system, the strut rod is modeled by beams and the strut tube to strut rod joint is modeled by a point to deformable curve constraint. This allows the strut to bend under load and captures the camber change due to lateral force common to strut suspensions.
![](../../images/post_processing/deformable_strut_system_example_mv.png)
Figure 1. Deformable Strut System
The deformable strut system is available in the MDLLIB’s MacPherson Strut front and rear suspensions and the rear quad-link suspension.
