Triamesh
Model ElementThe Triamesh element allows you to represent a geometric figure using a series of nodes and faces.
Class Name
Triamesh
Attribute Summary
Name | Property | Modifiable by command? | Designable? |
rm | Reference (Marker) | NO | NO |
nodes | Double (count=0) | ||
faces | Int (count=0) | ||
refinement_level | Int () | ||
material_inside | Bool () | ||
color | String() |
Usage
nodes = [[0,0,0],[1,1,1],[-1,1,1]]
faces = [[0,1,2]]
Triamesh(rm=rm,nodes=nodes,faces=faces)
Attributes
- rm
- Reference(Marker)
- nodes
- Int()
- faces
- Int()
- refinement_level
- Int()
- coils
- Int()
- material_inside
- Bool()
- color
- String()
- See Properties for an explanation about what properties are, why they are used, and how you can extend these.
