_impl.h3d file
A compressed binary file, containing both model and result data. It can be used to post-process results in HyperView or when using the HyperView Player.
File Creation
The _impl.h3d file is a general on-the-fly output file for nonlinear implicit runs. This is output on-the-fly when NLOUT Bulk/Subcase pair is specified in conjunction with PARAM,IMPLOUT,YES or if NLOUT argument on specific I/O Entries is specified pointing to NLOUT Bulk Data.
- PARAM,IMPLOUT,YES is defined in the model in conjunction with NLOUT Subcase/Bulk Data Entries.
- Results-specific output on-the-fly is activated using, for example, STRESS(NLOUT=<ID>).
File Contents
Result | Description |
Displacement | Displacement results from nonlinear analysis. Output is controlled by the DISPLACEMENT I/O option. |
SPC Force | Single-point force of constraint results from nonlinear
analysis. Output is controlled by the SPCFORCE I/O option. |
Strain | Strain results from nonlinear analysis. Output is controlled by the STRAIN I/O option. |
Stress | Stress results from nonlinear analysis. Output is controlled by the STRESS / ELSTRESS I/O option. |
Contact Results | Contact results from nonlinear analysis. Output is controlled by the CONTF I/O option. |
- Refer to PARAM, IMPLOUT and NLOUT for more information.
