.interface file
The .interface file is an ASCII format results file.
File Creation
This file is always created when acoustic analysis is performed.
File Contents
This acoustic coupling interface matrix visualization file contains element definitions.
  1. This file is used to verify the fluid/structure coupling matrix.
  2. Import this file into HyperMesh with the acoustic model already loaded. For best performance, ensure that the FE overwrite option is turned on in the HyperMesh import panel.
