Airbag Setup Recommendation
Airbag Materials
LAW19 Option | Recommended Value | Recommended Option Details |
RE | 0.001 < RE < 0.01 | If RE > 0.01 the compression stiffness is too high. |
ZeroStress | 1 | Airbag pre-strain is applied correctly. |
sens_ID | Use the same sensor as used in /MONVOL card | Fabric pre-strain through reference geometry must be activated at time to fire. |
LAW58 Option | Recommended Value | Recommended Option Details |
B1 and B2 | > 0 | B1 and B2 values should be positive. |
Flex | 0.01 | The default value is adequate. |
G0 < GT | -- | Shear parameters should be consistent. |
Enter value in degrees | Shear locking angle shall be entered in degrees. | |
sens_ID | Same sensor that is used in /MONVOL card | Fabric pre-strain through reference geometry must be activated at time to fire. |
Airbag Properties
Property Option | Recommended Value (per material) | Recommended Option Details | |
LAW19 1 | LAW58 2 | ||
Ish3n for trias | 2 | 2 | This is the default tria formulation. |
Ismstr for trias | 1 | 4 | Best practice recommendation for 3 node trias |
Ishell for 4-node shells | 12 | 12 | This formulation avoids hourglassing. |
Ismstr for 4-noded shells | 11 | 11 | Must be used with Ishell =12, 4 node shells. |
N | 1 | 1 | Enable membrane formulation |
Thick | > 0 | > 0 | Thickness must be defined |
Iplas | 0 | 0 | Not relevant for fabric |
Ithick | 0 | 0 | Not relevant for fabric |
Vx, Vy, Vz | Non-zero vector | Non-zero vector | This input defines a vector which determines first orthotropy direction. If not defined the Global X- axis is used. |
Idril | 0 | 0 | Not relevant for fabric |
Airbag Self-Contact
Interface Options | Recommended Value for contacts TYPE7, TYPE11 and TYPE19 | Comments |
Intersections | No intersections | No intersections are allowed. |
Penetrations | Penetrations < 95% gap | All penetrations > 95% gap need to be removed. |
Istf | 4 | Interface stiffness is the minimum of the master and slave stiffness. |
Stmin (kN/mm) | 1 | Avoids contact that is too soft. |
Idel | 0 | Not relevant for airbag self-contact. |
Igap | 0 | Constant gap is used as defined by Gapmin. |
Gapmin | 1.0 mm | For TYPE11, use Gapmin =0.9mm |
Inacti | 6 | Automatically remove initial penetrations by reducing the contact gap. |
Fric | 0 | No friction used in airbag self-contact. |
Ibag | 1 | Block vent holes and porous fabrics during contact. |
Interface Options | Recommended Value for TYPE23 | Comments |
Gapmin | Thickness of fabric material | This value determines both contact gap and contact depth, too high values will mean that intersected nodes will not be released due to too high contact depth. |
