Rigid Body (/RBODY)
A rigid body is defined by a set of slave nodes and a master node. It can be compared to a part with an infinite stiffness. No relative displacement is allowed between slave nodes, and the general motion of the rigid body manages the master node.
As a kinematic condition is applied on each slave nodes and for all directions, no other nodal constraint is allowed. However, in the case of the Lagrange Multiplier method, the solution can be found if no incompatible kinematic conditions are applied.
- Case 1:
- COG is computed with slave and master nodes mass and coordinates
- Case 2:
- COG is computed with slave nodes mass and coordinates only
- Case 3:
- COG is set at master node's coordinates
- Case 4:
It is strongly recommended to use an artificial node (not part of an element) as a master node, since Radioss Starter is likely to move the master node. The master node is moved by Radioss Starter to the center of gravity; unless the ICoG flag is set to 3 or 4. It is advised to set ICoG to 2 to get the most realistic behavior; the center of gravity is then computed taking into account only the slave nodes. If ICoG is set to 1, the master node, with its own mass, is included to compute the center of gravity.
- Rigid body covering a part of a finite element model, including shells, solids or other elements: In this case, the mass of slave nodes gives the total rigid body mass and no added mass is needed. The master node can be located anywhere, and it will be moved to the center of mass. This kind of rigid body saves a large amount of CPU time.
- Rigid body representing a non-modeled component connected on some structural nodes: In this case, only a few number of slave nodes are used to connect the rigid body to the finite element model. The mass and inertia are added and the master node is located at the component center of mass. The master node will only move a little, taking into account the mass of the slave nodes. In some cases, a dummy mesh is used to visualize the rigid body or to simulate the contacts, but if the dummy elements have a small mass, the previous remarks are still true.
- Rigid body used to connect two or more parts together: For these rigid bodies no added mass is needed and the master node can be located anywhere. A spherical inertia must be used for these rigid bodies; as these rigid bodies are usually very small (4 to 8 nodes), the inertia is often very small in one direction and very large for one specific direction. This may lead to instability; therefore, through the use of spherical inertia, inertia will be identical for any direction.
Activation/Deactivation
Rigid bodies can be activated or deactivated with /SENSOR or using the /RBODY/ON or /RBODY/OFF Engine options.
- /RBODY/ON
- 1 2
- /RBODY/OFF
- 3
Rigid Body Motions
One of the main uses of rigid body activation and deactivation concerns the roll-over motions, as in roll-over simulations. During the free flight of the car, the elements deformation can be neglected. A large part of CPU time can be saved if the whole structure is replaced with a temporary rigid body during the fly. Before the impact on the ground, this rigid body is deactivated and eventually activated again after rebound.
Initial Static Equilibrium
Merge Rigid Bodies
The /MERGE/RBODY option can be used to merge rigid bodies together or add slave nodes to an existing rigid body. The slave entities defined become slaves to a master rigid body. The slave entities can be rigid bodies, single nodes, or node sets. Multiple slave entities can be merged into one master rigid body by defining multiple lines in /MERGE/RBODY.
Some use cases include merging two different assemblies defined in two separate include files by defining the merge in the master input file. This can also be useful when separate parts defined as rigid need to be merged into one rigid body to model a complex component like an engine.
The master rigid body defined in /MERGE/RBODY can be defined as a slave rigid body in another /MERGE/RBODY. However, complex hierarchies should be avoided as they can become difficult to debug. The slave entities can only be defined in one /MERGE/RBODY and not in any /RBODY; otherwise, incompatible kinematic conditions occur.
Before merging, the inertia, mass, and center of gravity of each the slave and master rigid body is calculated based on their /RBODY properties. Next, the slave entities are merged to the master rigid body and new rigid body properties are calculated based on the /MERGE/RBODY Iflag option.
