Boundary Conditions
Boundaries with Lagrangian materials are declared automatically Lagrangian.
Nodes can be declared Lagrangian.
Constraints can be applied separately or simultaneously on:
Material velocity
Grid velocity
These constraints can be applied in one or several directions of a skew reference frame.
When the flag is set to 1, boundary condition is activated with global reference frame or skew
reference frame.
i = DOF with respect to global reference frame or skew reference frame
VELOCITY: Vi = 0
ACCELERATION: π i = 0
The boundary conditions can be changed during Engine runs with /BCS or
/BCSR Engine options.
ALE Links
An ALE link is identical to a rigid link. The slave node sets' grid velocity can be controlled by two master nodes, M1 and M2.
There are three options to choose from:
Option 0
Velocity is linearly interpolated with respect to order of
input.(1)
W
N
I
W
M
1
W
M
2
W
M
12
I
N
1
MathType@MTEF@5@5@+=
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf
MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi
ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8
qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9
q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake
aacaWGxbWaaSbaaSqaaiaad6eacaWGjbaabeaakiabg2da9iaadEfa
daWgbaWcbaGaamytaiaaigdaaeqaaOGaaGjcVlaaykW7cqGHRaWkda
qadaqaaiaadEfadaWgaaWcbaGaamytaiaaikdaaeqaaOGaeyOeI0Ia
am4vamaaBaaaleaacaWGnbaabeaakmaaBaaaleaacaaIXaGaaGOmaa
qabaaakiaawIcacaGLPaaadaWcaaqaaiaadMeaaeaacaWGobGaey4k
aSIaaGymaaaaaaa@4F23@
Option 1
Velocity is set to maximum absolute velocity of master
nodes.(2)
W
N
I
W
M
1
if
W
M
1
W
M
2
feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4vamaaBa
aaleaacaWGobGaamysaaqabaGccqGH9aqpcaWGxbWaaSbaaSqaaiaa
d2eacaaIXaaabeaakiaaywW7caqGPbGaaeOzaiaaywW7daabdaqaai
aadEfadaWgaaWcbaGaamytaiaaigdaaeqaaaGccaGLhWUaayjcSdGa
eyipaWZaaqWaaeaacaWGxbWaaSbaaSqaaiaad2eacaaIYaaabeaaaO
Gaay5bSlaawIa7aaaa@4DC6@
Option 2
Velocity is set to minimum absolute velocity of master
nodes.(3)
W
N
I
W
M
1
if
W
M
1
W
M
2
The input data is specified at each restart run.
