The relationship between the physical coordinate and computational intrinsic coordinates
system for a brick element is given by the matrix equation:
(1)
Hence:
(2)
Where,
- Jacobian matrix
The element strain rate is defined as:
(3)
Relating the element velocity field to its shape function gives:
(4)
Hence, the strain rate can be described directly in terms of the shape
function:
(5)
As was seen in Velocity Strain or Deformation Rate, volumetric strain rate is calculated separately by volume variation.
For one integration point:
(6)
F.E Method is used only for deviatoric strain rate calculation in A.L.E and Euler
formulation.
Volumetric strain rate is computed separately by transport of density and volume
variation.
