Contact Interface Time Step Control
- /DT/INTER/Keyword3/Iflag
/DT/INTER/CST
Automatically increases the mass of nodes involved in contact to maintain the entered value. Normally this option is not useful since contact slave nodes with low time steps typically have high penetration into the contact gap and when mass is added their kinetic energy increases which causes increased penetration and thus model instability. The amount of added mass should be monitored during and checked after the simulation in the same manner as /DT/NODA/CST.
/DT/INTER/DEL
Removes nodes involved in a contact interface that are causing the time step of the simulation to drop below . This option can be very useful to maintain a specified time step, but if the number of removed nodes is too large, then the contact will not be correct, and the results may not be accurate.
/DT/INTER/STOP
Stops the simulation when the contact interface time step drops below the entered value. Many times, a reduction in time step is caused by a model's instability, so stopping the simulation can be useful to diagnose the issue.
/DT/INTER/AMS
Applies Advanced Mass Scaling to interface slave nodes to maintain the constant time step, . Refer to Advanced Mass Scaling (AMS) for more information.
