Save Files
Save all of the data in your current session.
- From the Home tools, Files tool group, click the Save tool.
Figure 1. - From the menu bar, select to save the model under its current name.
- From the menu bar, select to save the model under a new file name and/or directory.
On Linux, the directory is /usr/tmp/Fatigue/RunHistory/
You can change the directory from the Preferences dialog.
