hm_entityrecorder
Records the IDs of the entities created while the recorder is enabled.
hm_entityrecorder entity_type option
HyperMesh Tcl Query Command
Records the IDs of the entities created while the recorder is enabled. This is useful for finding the IDs of multiple entities created during various processes.
The recorder must be turned on to enable recording. It is also important to make sure to turn off the recorder. See the option argument below.
entity_type
The type of entity to record. If set to 0, all entity types are recorded.
option
on - Turn on the entity recorder.
off - Turn off the entity recorder.
ids - Get the list of IDs recorded while the recorder is on.
count - Get the number of IDs recorded while the recorder is on.
To record the created components and get the number and list of recorded IDs:
hm_entityrecorder comps on;
<create components>
hm_entityrecorder comps off
set num_comps [hm_entityrecorder comps count]
set comp_ids [hm_entityrecorder comps ids]
   # Handle error
Version History
12.0
