animate framerate
Sets the animation frame rate.
animate framerate <framerate>
Argument
- framerate
- The animation frame rate.
animate framerate 4
Use HWC commands in the Tcl Console.
Animation controls.
Sets the animation frame.
Linear animation options.
Modal animation options.
Sets the animation mode.
Advance to the next frame.
Return to the previous frame.
Start the animation.
Stop the animation.
Transient animation options.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Tracking system commands.
View manipulation.
Animation controls.
animate framerate 4
