hide model
Hides all or parts of a model.
hide model all
hide model <id>
Arguments
- all
- Hides all models.
- <id>
- Hides models based on ID. For example,
(1,2,4)
For example, (1-3,5,7).
Examples
hide model all
hide model 5
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Tracking system commands.
View manipulation.
hide model all
hide model <id>
(1,2,4)
For example, (1-3,5,7).hide model all
hide model 5
