result scalar
ClassicCreate and manage the contour plot.
result scalar argument ?argument? ?argument? <name1>=<value1>
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Clears the contour plot.
Turns on/off discrete colors in the contour plot.
Clears the scalar plot from the modeling window.
Interpolates the contour colors from the undeformed shape, with a zero value, to the result variable reported from the solver.
Edits the contour plot's legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Loads and plots scalar data types.
The multiplier for scaling all the result values.
Enter a value that will affect the contour value, contour min/max, and the legend min/max.
Displays the current scalar plot in the modeling window.
Makes a subcase current.
ClassicCreate and manage tensor plots.
ClassicCreate and manage vector plots.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Tracking system commands.
View manipulation.
Result loading.
ON THIS PAGE
ON THIS PAGE
