tracking create
Creates a new tracking system.
tracking create <name>
Argument
- <name>
- The tracking system name.
tracking create "Tracking System 1"
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Tracking system commands.
Deletes a tracking system.
Applies options to the current tracking system.
Activates a tracking system.
Renames the tracking system.
View manipulation.
