hwIH3DExportOptions GetWriteEntityIDs
Queries whether entity IDs will be written with the file.
hwIH3DExportOptions_handle GetWriteEntityIDs
HyperWorks Tcl Query
Returns true or false, depending on whether writing entity IDs is enabled.
Largely ignored in 6.0 and later. In previous versions, there was an advantage in efficiency to writing index-based files. This is no longer true.
To check if entity IDs will be written:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWriteEntityIDs
None.
