hwIReportTemplate SetParameterValue
Sets the parameter of a report.
hwIReportTemplate_handle SetParameterValue name, value
HyperWorks Tcl Modify
This command sets the parameter value (the input area in the GUI for parameter).
- name
- The name of the parameter that you want to set.
- value
- The value or filepath that you want to set in the parameter.
hwi GetSessionHandle sess;
sess GetReportTemplateHandle rep 1;
rep SetParameterValue dat_file
c:/demos/mv_hv_hg/reports/text_summary/sdf.dat;
Error
Keywords
HyperWorks
Tcl
Report Template
Template
Modify
