Table of Reference
Add a table of reference to the report.
- Right-click Report and select Note: Report allows you to add only one Table of Reference for the session..
Figure 1. - Once Table of Reference is added, a chapter titled Table of Reference is added to
the tree. Also, a table entity titled Table of Reference is added under it.
Figure 2. - Below are the properties associated with the Table entity.
Figure 3.- Name: You change edit the name property of the reference table entity.
- Caption: Provide a caption for the table entity. This caption is visible in the exported Word report.
- Data: Edit data to the table entity. Data entry to the table can be done
through two methods.
Figure 4.- Manual - Enter the required number of rows and columns and click
Update. This adds the number of rows
and columns where you can enter the data manually.
Figure 5. - Import - Import table data from a CSV or XLSX file.
- Click Import. A file browser option is displayed.
- Select a file and click OK. This imports the
data from the file and populates the table entity.
Figure 6.
Advanced
- Location of Caption: Select the caption location from the list. These are standard
locations as present in Microsoft Word. Table caption locations can be:
Figure 7.- Below Table, or
- Above Table
- Auto Split Table: Provides the function to split up tables automatically based on
the space available in the slide or page.
Adding a reference
- To add a reference, select the required text and right-click Insert Table
of Reference.
Figure 8. - A table of reference option is displayed. Select the required cell from the table
and click OK. This adds a
reference for the selected text item to the cell item in the table.
Figure 9.Adding a Cross Reference
- To add a cross reference, select the required text and right-click Add
Cross Reference.
Figure 10. - A Select Item to Cross Reference dialog opens. You can select
the required entity from the table and click OK.
Figure 11.
