Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes with
the Parameters Browser.
Use the Process Manager to rapidly develop and deploy process automation applications for standard product engineering practices within the
HyperWorks environment using the Process Manager.
Learn how the Task Builder helps you to create new tasks, data types, and processes, and save them inside of catalogs
that are easily accessible from the Task and Process browsers.
During an Automate session, you can save your work in progress, and at any given time reload the session and resume
working from the exact point where you left off.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
On the tree in the Task Browser, click Demo > Basic > Math > MathTask.
Note: Your Task Browser should include a default catalog called MathTask. If the
catalog does not appear on the tree of the Task Browser, load the catalog
file from the HyperWorks installation directory
on your system:
<install_directory>\demos\automate\1_math_task_basic_datatype.
Drag and drop the MathTask into the Process Modeling window. This task is
pre-defined to add two inputs and produce one output as follows:
input_1 = 1
input_2 = 2
output = 3
Note: input_1, input_2 and output are element attributes that you can define in
the Task Implementation file.
On the toolbar, click to
execute the task.
The results of the task are
displayed in the command window, as you see outlined in red in
the following image:
Tip: If the command window is hidden on your
screen, hover over the edge of the Process Modeling window, and then click and drag
to open the command window.
